Cesky English Deutsch
Login/Register:
 Visitors: 3738
CAD tip CAD tip # 11479:
"Assertion failed" error when launching AutoCAD.
A - answer Launching AutoCAD leads to an (ignorable) error message "Assertion failed" in IsValidToAddQATItem.
This error is reported by Windows (the XML module) - the module may be damaged or the XML files of the AutoCAD CUI menu may be damaged. Please try to update the ACAD.CUIX file (from another PC, from a backup or from your installation media), or just perform a repair installation of your AutoCAD and (re)install the latest AutoCAD updates (service packs, hotfixes).
ACADLT
16.6.2017    3253×
Comments   Tell a friend
applies to: AutoCAD · AutoCAD LT ·
Tip 8482:How to convert CUI file to MNU or CUIX to CUI?
Tip 7896:AutoCAD displays an empty ribbon only.
Tip 7604:How to decompile a CUIX menu file?
Tip 4277:What are the .CUI files?
Tip 2410:How to export a XML file from AutoCAD?
Quickly repeat last command in Fusion 360 (like Enter in AutoCAD) « | » Why you should not use the DEFPOINTS layer to draw geometry?
