<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE rss PUBLIC "-//Netscape Communications//DTD RSS 0.91//EN" "http://my.netscape.com/publish/formats/rss-0.91.dtd">
<rss version="0.91">
	<title>CAD Forum tips (EN)</title>
	<link>http://www.cadforum.cz</link>
	<description>3863 CAD tips and tricks - AutoCAD, LT, Inventor, Revit, 3ds max, Fusion and other Autodesk products</description>
	<language>en-US</language>
	<copyright>(C)2024 - ARKANCE</copyright>
	<managingEditor>webmaster.cz@arkance.world</managingEditor>
	<webMaster>webmaster.cz@arkance.world</webMaster>
  <url>https://www.cadforum.cz/en/img/cadforum.gif</url> 
  <title>CAD Forum</title> 
  <link>https://www.cadforum.cz</link> 
  <width>88</width> 
  <height>31</height> 
  <description>CAD Forum - hundreds of CAD tips and tricks</description> 
 <link>https://www.cadforum.cz/en/how-to-display-the-name-of-the-current-layer-in-autocad-status-tip15165</link>
 <title>How to display the name of the current layer in the AutoCAD ...</title>
 <description>Tip: How to display the name of the current layer in the AutoCAD status bar? - See answer</description>
 <link>https://www.cadforum.cz/en/7-types-of-installation-of-the-cad-application-autodesk-fusion-tip15164</link>
 <title>7 types of installation of the CAD/CAM application Autodesk ...</title>
 <description>Tip: 7 types of installation of the CAD/CAM application Autodesk Fusion. - See answer</description>
 <link>https://www.cadforum.cz/en/automatic-detection-of-symbols-in-pdf-sheet-in-autodesk-takeoff-tip15161</link>
 <title>Automatic detection of symbols and tags in a PDF sheet in ...</title>
 <description>Tip: Automatic detection of symbols and tags in a PDF sheet in Autodesk Forma Takeoff. - See answer</description>
 <link>https://www.cadforum.cz/en/how-to-collaborate-on-dwg-files-simultaneously-multiplayer-mode-tip15155</link>
 <title>How to collaborate on DWG files simultaneously (multiplayer ...</title>
 <description>Tip: How to collaborate on DWG files simultaneously (multiplayer mode, concurrent editing)? - See answer</description>
 <link>https://www.cadforum.cz/en/searching-for-geometrically-similar-parts-duplicates-in-fusion-tip15151</link>
 <title>Searching for geometrically similar parts and duplicates in ...</title>
 <description>Tip: Searching for geometrically similar parts and duplicates in Fusion Hub. - See answer</description>
 <link>https://www.cadforum.cz/en/displaying-the-value-of-a-text-field-including-the-sign-plus-tip15147</link>
 <title>Displaying the value of a text field, including the sign ...</title>
 <description>Tip: Displaying the value of a text field, including the sign (incl. the ‘+’ sign) - See answer</description>
 <link>https://www.cadforum.cz/en/how-to-create-a-point-at-the-center-of-gravity-of-a-sketch-curve-tip15141</link>
 <title>How to create a point at the center of gravity of a sketch ...</title>
 <description>Tip: How to create a point at the center of gravity of a sketch curve in Autodesk Fusion. - See answer</description>
 <link>https://www.cadforum.cz/en/autocad-field-formatting-codes-full-list-tip15138</link>
 <title>AutoCAD Field formatting codes - full list.</title>
 <description>Tip: AutoCAD Field formatting codes - full list. - See answer</description>
 <link>https://www.cadforum.cz/en/the-convenient-navigator-in-autodesk-fusion-tip15136</link>
 <title>The convenient Navigator in Autodesk Fusion.</title>
 <description>Tip: The convenient Navigator in Autodesk Fusion. - See answer</description>
 <link>https://www.cadforum.cz/en/regular-expression-syntax-for-srxtext-regexp-tip15131</link>
 <title>Regular Expression Syntax - for srxText, RegExp, rRename...</title>
 <description>Tip: Regular Expression Syntax - for srxText, RegExp, rRename... - See answer</description>
