CAD tip CAD tip # 8832:
Question
By combining the Inventor functions Helix and Bend part you can easily create a parametric helix (spiral, spring, coil) bent to an arc shape.
Samples of helix IPT parts can be downloaded from the Block catalog - see Bent helix.
Spiral bent to arc
Inventor
29.9.2012   9838×
this tip shared by ARKANCE experts applies to: Inventor ·
Tip 14405:How do I create a 3D helix or 2D spiral sketch in Fusion?
Tip 14242:How to find the minimum, maximum or local extreme of a 2D or 3D curve?
Tip 13906:How to construct a 2D spiral shape in Inventor?
Tip 13183:Lin2Cyl - bulk conversion of lines to 3D cylinders.
Tip 12479:PkLength - export line lenghts to Excel.
Back    All CAD Tips
Categ:
