CAD tip CAD tip # 9222:
Question
Direct CAD modeler Inventor Fusion 2013 can open virtually any 3D CAD format. Imported or designed 3D data can be exported from Fusion to many CAD formats - so you can use this application also as a CAD formats converter.
Fusion 2013 supports export to:
  • DWG (native)
  • Catia V5 (CATPart, CATProduct)
  • AutoCAD DWG 2010
  • DWF
  • DXF
  • STL
  • SAT (ACIS)
  • IGES
  • Parasolid (X_T, X_B)
  • Pro/Engineer Granite (G)
  • STEP
  • VRML
See DL Download
Fusion2013
23.4.2013   8828×
this tip shared by ARKANCE experts applies to: Fusion 360 2013 ·
Tip 14864:How to generate a spirograph curve, guilloche, for CAD applications?
Tip 14836:AutoCAD doesn't show my installed TTC font (TrueType Collection)
Tip 14709:How to export Fusion drawings to AutoCAD (DWG)?
Tip 14681:How to quickly convert XLS tables to CSV format without opening Excel?
Tip 14560:JobTime for Autodesk Fusion - tracking time spent on a job.
Back    All CAD Tips
Categ:
