CAD tip CAD tip # 7419:
Question
AutoCAD Civil 3D may refuse loading (import) of point list with the error message 'Point number' verification error - value '2010061234' is out of range.
This is caused by a too high value used for a point number. AutoCAD Civil 3D supports numbers in the interval of unsigned longint, i.e. 0 to 4,294,967,295 (4294967295). Use lower numbers, without any non-numerical characters. If you need to store higher values, please use the point name or define a new custom property for the points.
Civil2011Civil2010Civil2009
23.6.2010   13773×
this tip shared by ARKANCE experts applies to: Civil 3D 2011 · Civil 3D 2010 · Civil 3D 2009 ·
Tip 14911:Using symbolic variables to enter repeated values in AutoCAD.
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14808:How to import a KML/KMZ file from Google Maps, including placemark labels, into AutoCAD Map 3D?
Tip 14711:How to generate a random 2D or 3D point cloud in AutoCAD?
Back    All CAD Tips
Categ:
