  Visitors: 5648
CAD tip CAD tip # 11409:
Catalog of all available hatch patterns.
A - answer If you want to create a visual catalog of all currently available hatch patterns (.PAT hatches) on your computer, you can use the freeware utility by CAD Studio - PatCatalog. This LISP application for AutoCAD automatically generates an overview table of all (or just ACAD.pat/ACADiso.pat) hatch patterns found on your PC (in AutoCAD search path), with visual samples.
Download PatCatalog from Download, load it into your AutoCAD with APPLOAD and run it by typing the command PATCATALOG. Its function is automatic.
hatch patterns - srafy
You can download additional hatch patterns from Download
See also a similar application LinCatalog for linetypes
ACAD
3.5.2017    22437×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13802:Dual-color hatches in AutoCAD.
Tip 13590:How to set the hatch background color?
Tip 12018:How to transfer an AutoCAD hatch pattern to Revit?
Tip 11538:AutoCAD will not create a specific hatch in a given scale or area.
Tip 11415:Error in pattern file. Missing parameter on line XXX.
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
