Over 1.124.000 registered users (EN+CZ).
CAD tip # 8815:
Question
When working on complex projects, you will often need to hand over a limited area of the drawing documentation to an external team member or to a cooperating company. This transfered DWG documentation usually should include also all related xrefs.
The procedure for clipping a complex drawing is described on the Civil3D blog - How to bone complex drawings (in Czech).
MapCivil
13.9.2012
13701×
this tip shared by ARKANCE experts applies to: AutoCAD Map 3D · Civil 3D ·
