CAD tip CAD tip # 7963:
Question
Inventor Fusion 2012 (localized) is now part of AutoCAD 2012 and Inventor 2012. This software for direct, interactive editing of 3D models can be invoked right from the AutoCAD and Inventor environments (not neccessary to launch it separately).
Thanks to the direct editing and its automatic recognition of construction features, you can use Fusion to load and "intelligently" edit any 3D CAD model, including the STEP, Catia, Solidworks, Pro/E etc. formats. The edited model can be saved to a DWG file, or processed in Inventor.
An example of the Fusion edit functionality on an imported STEP assembly can be seen in the CAD video #48:
Fusion 2012 CZ
ACAD2012Inventor2012
9.5.2011   9778×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · Inventor 2012 ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14999:How to add custom HDRI background (environment) for rendering in Fusion?
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Tip 14986:How to launch Autodesk Fusion online, in a web browser?
Tip 14983:Fusion no longer generates stock material in machining projects.
Back    All CAD Tips
Categ:
