CAD tip CAD tip # 7874:
Question
The IMPORT command in AutoCAD 2012 newly supports loading of 3D models in a number of exchange formats and native formats of foreign CAD applications. So you can easily work with the 3D models (parts, assemblies) from other CAD software tools.
AutoCAD 2012 supports e.g. the formats of CATIA V4 (.model, .exp), CATIA V5 (.CATPart, .CATProduct), IGES (.igs, .iges) - also export, JT (.jt), NX (.prt), Parasolid (.x_b, .x_t), Pro/E (.prt, .asm), Pro/E Granite (.g), Pro/E Neutral (.neu), Rhino (.3dm), Solidworks (.prt, .sldprt, .asm, .sldasm), STEP (.stp, .step).
Formats in 2012 (CZ version)
IGES files can processed also with the commands IGESIMPORT and IGESEXPORT
ACAD2012
28.3.2011   15355×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 ·
Tip 14953:Importing ECLASS files into AutoCAD Electrical.
Tip 14944:How to import or export an SVG file in AutoCAD? (SVGimport/SVGexport)
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 14808:How to import a KML/KMZ file from Google Maps, including placemark labels, into AutoCAD Map 3D?
Back    All CAD Tips
Categ:
