CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2654
CAD tip CAD tip # 8391:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 8630:How to create red-cyan anaglyph from AutoCAD, Inventor or Revit?
Tip 8553:Import SketchUp files into AutoCAD (SKP-DWG).
Tip 7874:Direct support for IGES, CATIA, Pro/E, Solidworks, NX etc. in AutoCAD 2012.
Tip 7589:Import and export IGES files in AutoCAD (DWG).
Tip 7518:How to save Civil 3D objects to an older version?
Is AutoCAD 2012 for Mac compatible with Mac OS X Lion? « | » Where can I find the Inventor Tutorial Files?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
