CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products []
Cesky English Deutsch
 Visitors: 2581
CAD tip CAD tip # 10761:
Dynamic block attributes do not respect visibility states.
A - answer Non-constant attributes of dynamic block yield to display control through "visibility states" (and other dynamic actions) only of they are locked.
In the dynamic block editor, open the Properties palette (Ctrl+1) and set the property "Lock position" (the last row) for the given attribute to Yes. Then Attsync the changed block.
23.2.2016    2354×
Comments   Tell a friend
applies to: AutoCAD ·
Tip 11439:Replace block instances (incl. dynamic) with another block.
Tip 11404:Operations with attributes inside a block - fields.
Tip 8593:Disable dynamic previews when changing object properties.
Tip 7583:Select dynamic blocks by dynamic properties.
Tip 7025:How to insert the surface symbol (roughness)?
How to block specific AutoCAD commands? « | » How to publish a DWG to a PDF file without attaching "-Model" to its name?
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
