CAD tip CAD tip # 9291:
Question
Since version 2014 you can more easily uninstall individual products and products of the Autodesk Design Suites (Building Design Suite, Product Design Suite, Infrastructure Design Suite, etc.). So if you e.g. upgrade to a newer version, or you need to batch-uninstall a trial version, you can now use the new "Uninstall Tool". No more manual sequential uninstallation of all individual applications.
This tool can be found in the Start menu, or in the folder \Program Files\Common Files\Autodesk Shared\Uninstall Tool\. You can choose which apps to uninstall:
BDS uninstall
DesignSuite2014InvRevitmax
12.6.2013   19359×
this tip shared by ARKANCE experts applies to: DesignSuite2014 · Inventor · Revit · 3ds Max ·
Tip 15007:In AutoCAD, the Ortho mode on the Shift key suddenly stopped working.
Tip 14941:Fusion: The code execution cannot proceed because Qt6Widgets.dll or acge230.dll was not found.
Tip 14896:When starting up, Fusion gets stuck on "Loading additional modules."
Tip 14695:Beware of Windows Update - AutoCAD suddenly requires an Administrator login on launch.
Tip 13988:How do I uninstall hotfixes, updates and apps that cannot be uninstalled via Control Panel?
Back    All CAD Tips
Categ:
