CAD tip CAD tip # 9084:
Question
With the AutoCAD command DCCONVERT you can create a parametric drawing from a plain dimensioned geometry - such drawing is controlled by a table of numerical parameters.
The conversion procedure changing dimensions to parameters is described in a video from the CAD Videos section:
AutoCAD video #51
AutoCAD-parameters
or on CAD Studio's YouTube channel:
ACAD2013ACAD2012ACAD2011
11.2.2013   10140×
this tip shared by ARKANCE experts applies to: AutoCAD 2013 · AutoCAD 2012 · AutoCAD 2011 ·
Tip 15032:Naming PDF files from Revit based on sheet number and sheet size.
Tip 15030:How to increase the number of Recent Folders displayed in Inventor dialogs?
Tip 15014:Why doesn't AutoCAD display the Length, Width, and Height properties of a 3D box?
Tip 15003:Using lookup table to control parameters of a dynamic block - clock.
Tip 14980:How to calculate weight of structural members in a Revit schedule?
Back    All CAD Tips
Categ:
