CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2427
CAD tip CAD tip # 7210:
Editing selected segments of a polyline.
A - answer AutoCAD 2010 can select subobjects of a given entity by holding the Ctrl key when selecting the entity. With the CTRL key you can e.g. select only some segments of a polyline.
The grips of the selected segments will automatically become hot (selected) grips and you can directly modify these segments (e.g. move) using grip-editing.
Ctrl-select segments
This behaviour is can be suppressed with the LEGACYCTRLPICK variable.
ACAD2010LT2010ADT2010Civil2010Map2010
9.2.2010    2460x
Comments   Tell a friend
Tip 7998:How to change a straight polyline segment to arc segment?
Tip 7099:Blocks perpendicular to a polyline.
Tip 6972:How to remove arc segments from Pline?
Tip 6955:Simply add or delete a polyline vertex.
Tip 6895:How to use spline as a breakline in Civil 3D?
Batch replace different blocks with a single block. « | » Sharp spikes plotted in certain letters.
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2012 More info
