CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2073
CAD tip CAD tip # 7477:
Error in Photofly: An error occured with the Web Service (Error:0)
A - answer When you try to start Photofly (the Photo Scene Editor from Autodesk Labs - PSE_APP.exe, or a .RZI file) on your system, the application fails with the error message "An error occured with the Web Service. Check your connection. (Error:0)".
You are probably using an incompatible operating system (e.g. an older WinXP SP2) - the Photo Scene Editor requires Windows XP SP3 or Windows 7 (32/64-bit). Or you are not connected to the Internet.
Use always the latest version of the Photo Scene Editor (see PhotoSceneEditorInstaller.msi) to communicate with the Project Photofly web cloud service.
Photofly
28.7.2010    1507x
Comments   Tell a friend
applies to: Photofly ·
Tip 8118:How to get "User ID" for Autodesk web services?
Tip 8077:Firefox doesn't display 3D DWF data in the QuickShare viewer.
Tip 7616:Convert photos to 3D model - also for patios.
Tip 6504:Two methods for creating Inventor 3D models from 2D views.
Tip 6329:Intuitive overview of relationships and constraints in Inventor assemblies.
Dotted and arrow linetypes. « | » Reset AutoCAD user settings - reinitiate the secondary installer.
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2012 More info
