Over 1.124.000 registered users (EN+CZ).
CAD tip # 9126:
Question
The error message "Error in RSe clone commander" (e.g. during Assembly Demote) indicates a problem in the assembly structure - Inventor fails on creating a copy (clone) of the assembly structure.
Apply the latest service packs for your Inventor version, or try to remove "suspicious" constraints, or modify the structure of the original assembly (adaptive components, subassemblies, etc.).
RSe Clone Commander errors are usually fixable - provide the complaining model to Autodesk support.
Inventor
5.3.2013
14802×
this tip shared by ARKANCE experts applies to: Inventor ·
