CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2535
CAD tip CAD tip # 7888:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 8600:Use BCount (Express Tools) with dynamic blocks.
Tip 8365:Inventor understands many different measurement units.
Tip 8214:Loading Express Tools - missing ET in AutoCAD.
Tip 8121:Do you know the AutoCAD command "space invaders"?
Tip 7901:How to redirect AutoCAD BAK files to another folder?
How to find missing numbers in a series of numbered blocks? « | » Inventor trick - new empty drawing sheet.
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2012 More info
