Cesky English Deutsch
Login/Register:
 Visitors: 6817
CAD tip CAD tip # 10774:
Error: Some or all of the family files you selected cannot be loaded.
A - answer When trying to load a RFA family file into Revit, you get the error message:
Some or all of the family files you selected cannot be loaded. You must choose family files of the category XYZ. Do you want to retry loading a new set of files?
You are probably trying to load a specific type of family from a running insert command - e.g. inserting a new window type from the Window command. To load any type of RFA file to your current project, use the command Insert > Load from Library > Load Family.
Revit
6.3.2016    2917×
Comments   Tell a friend
applies to: Revit ·
Tip 11635:Where can I download content libraries for Revit?
Tip 10552:Which Revit version will open a RVT file on double-click?
Tip 10097:Multiple applications with the same name in the "Open with" menu - which to choose?
Tip 9852:How to convert 3D CAD solids to Revit parametric BIM families?
Tip 9246:Pipe label in Revit MEP - outer diameter x wall thickness
The "Render" command is not active. « | » What is the orange marker on the sketch icon in Fusion 360 model tree?
