Cesky English Deutsch
Login/Register:
 Visitors: 3708
CAD tip CAD tip # 11240:
Fusion360: Extrusion offset from a sketch plane.
A - answer If you need to create a 3D model by extruding an profile offset from a skecth plane, it is not neccessary to prepare an auxiliar workplane. You can directly enter the offset value in the Extrude command - either numerically or relative to another plane.
Fusion360
3.1.2017    2478×
Comments   Tell a friend
applies to: Fusion360 ·
Tip 11522:How to create 3D splines in Fusion 360 - e.g. for pipe axes?
Tip 11234:3D relief on model surface in Autodesk Fusion 360.
Tip 11226:Mass rename (string replace) of Fusion 360 components.
Tip 10936:Using assemblies in Inventor LT.
Tip 10769:What is the orange marker on the sketch icon in Fusion 360 model tree?
Labels with incrementing numbers - assembly with numbered labels for laser cutting. « | » 3D relief on model surface in Autodesk Fusion 360.
