Cesky English Deutsch
Login/Register:
 Visitors: 5811
CAD tip CAD tip # 11386:
Hatches in AutoCAD 2015 (and higher) do not display linetypes.
A - answer In my drawings, I have used hatches showing linetypes (dashed, complex). AutoCAD 2015 now displays these hatches only as plain continuous lines.
The AutoCAD version 2015 (and higher) offers a new system variable HPLINETYPE which controls displaying linetypes in hatch objects. Linetypes in hatches are off by default to preserve performance. If you want to show linetypes in hatches, set the HPLINETYPE variable to 1.
ACAD2015LT2015ACADLT
12.4.2017    1396×
Comments   Tell a friend
Tip 11729:Select objects by annotation scale.
Tip 11409:Catalog of all available hatch patterns.
Tip 9350:How to move the draw order of all images or hatches to back?
Tip 8996:Material-based hatch patterns in Inventor section views.
Tip 8460:Unusual AutoCAD linetypes - from Microstation RSC files.
How to edit large STL files in Fusion 360? « | » Annotating foundations - when they are created as walls.
