Cesky English Deutsch
Login/Register:
 Visitors: 8090
CAD tip CAD tip # 9644:
How can I mirror my drawing without mirroring the blocks (symbols)?
A - answer If you have AutoCAD LT only, you can use the following steps:
  1. select all newly mirrored objects (Grip-Edit)
  2. in the Properties-Palette (Ctrl+1), filter only the block references (see the top row)
  3. change the field "Scale X" from -1 to 1 (for horizontal mirroring), or use Scale Y (for vertical mirroring)
If the insertion point of the symbols (blocks) is not symmetrical, the blocks may be displaced.
LTACAD
14.1.2014    2864×
Comments   Tell a friend
applies to: AutoCAD LT · AutoCAD ·
Tip 11404:Operations with attributes inside a block - fields.
Tip 11198:Justified attribute text in mirrored blocks (AutoCAD)
Tip 6251:Text mirroring options in dynamic blocks in AutoCAD.
Tip 2314:How to select all mirrored blocks in a drawing?
Tip 1451:How to mirror a block with text when text should remain readable?
PDF print error - cannot print document. « | » How to open the folder with your current DWG drawing?
Export 3D VRML scenes from AutoCAD and Inventor 2015
VRMLout More info
