CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1449
CAD tip CAD tip # 8484:
How to apply material to a single face only?
A - answer Any scene material (from the Material palette) in AutoCAD can be assigned not only to the whole object, but alternatively also to a specific face on the 3D object.
In older AutoCAD versions (2009 and older), right-click on the selected material in the Materials palette and use the "Apply material" function. On the object then select the specific 3D face with the Ctrl key.
In newer versions of AutoCAD (2010 and higher) with the new unified material editor, first choose the requested faces on the 3D object (as sub-objects, i.e. with the Ctrl key) and in the material palette click on the image of the requested rendering material.
Material on face
You can also use the SOLIDEDIT command with the option Face and Material -- identify the face by its edges and enter the name of the requested material.
Another option is the command MATERIALASSIGN; on the "Select objects:" prompt enter Subobject and select the requested face or faces.
ACAD
23.2.2012    2869x
Comments   Tell a friend
applies to: AutoCAD ·
Tip 8903:Draw normals of 3DFaces in AutoCAD DWG.
Tip 8632:Talking iLogic rule to check part material in Inventor (default material).
Tip 8597:Flashing, patchy appearance of Revit 3D models in Showcase.
Tip 8487:How to change tree color in Revit shaded view?
Tip 8151:Keyboard shortcuts in AutoCAD for Mac.
How to change tree color in Revit shaded view? « | » How to convert CUI file to MNU or CUIX to CUI?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
