Over 1.124.000 registered users (EN+CZ).
CAD tip # 9258:
Question
If you need to borrow a license from your network license server for local (off-line) usage, use the Autodesk 3ds Max Design function "Borrow license". You can find it in the pull-down menu Help > License Borrowing > Borrow license. In the dialog then choose the date you want to return this license.
Please note that license borrowing is available only in 3ds Max installed as a network license (NLM).
max2014max2013
20.5.2013
14955×
this tip shared by ARKANCE experts applies to: 3ds Max 2014 · 3ds Max 2013 ·
