Cesky English Deutsch
Login/Register:
 Visitors: 5598
CAD tip CAD tip # 11757:
How to change blocks properties ex-post: annotative, allow exploding, scale uniformly
A - answer If you incorrectly set a block property in the dialog of the BLOCK command, there seems to be no obvious way to change this property ex-post, later.
But it is quite easy, and it is not necessary to explode the block and start over. Launch the block editor BEDIT, choose the block to edit and then display the Properties palette (Ctrl+1) in the block editor. Do not select any geometry. At the end of the property list, you can find the panel with "global" properties of the block and you can modify them as needed - e.g. Annotation, Uniform scale, Allow exploding, Units, Description, Hyperlink. Then save the modified block (Close block editor).
Later modification
ACADLT
15.1.2018    1516×
Comments   Tell a friend
applies to: AutoCAD · AutoCAD LT ·
Tip 11898:Automatic schedule - number of blocks in a drawing.
Tip 11896:How to drive dyn.block parameters or constraints from Excel?
Tip 11780:How to rename layouts by a specific attribute of the title block?
Tip 11614:How to reorder custom properties in a dynamic block?
Tip 11492:Adding selected numbers in drawing texts - counting numbers (GrSelNum).
Parametric constraints between 3D objects in AutoCAD. « | » toMulti converts polylines to multi-lines driven by a definition table.
Link your AutoCAD texts with Excel tables/sheets. Export. Change. Import.
Try DwgText 2015 More info
