CAD tip CAD tip # 8776:
Question
Since Revit 2009 you can change field-of-view of Revit cameras directly, not only by changing the crop region. You can specify the camera lens FOV graphically, there is no numerical input (parameter).
Display the SteeringWheel in a 3D view by pressing F8 (or Shift+W). In its context menu (bottom-right triangle) click on the option "Adjust focal length". By moving your mouse then adjust the field of view (lens angle) for the current camera.
Camera FOV
See:
Revit2013Revit2009
23.8.2012   38806×
this tip shared by ARKANCE experts applies to: Revit 2013 · Revit 2009 ·
Tip 14433:AR view of 3D model from AutoCAD, Inventor, Revit, Fusion
Tip 9965:How to create a 360° spherical panorama of your CAD model?
Tip 9055:Choosing a 3D view type in Revit - perspective, orthographic
Tip 8597:Flashing, patchy appearance of Revit 3D models in Showcase.
Tip 7319:3ds Max import - AutoCAD Drawing vs. Legacy AutoCAD - the differences.
Back    All CAD Tips
Categ:
