CAD tip CAD tip # 8199:
Question
Components in Inventor 2012 assemblies are highlighted in dark red when you move your mouse over them. How to dim this highlighting or make it more transparent?
Go to: Tools > Application options > Colors and uncheck the option "Enable Advanced Highlighting". The individual parts will be highlighted the same way as in the version 2011 and older.
Highlighting options (CZ version)
Inventor2012
9.9.2011   10293×
this tip shared by ARKANCE experts applies to: Inventor 2012 ·
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Tip 14996:How do I configure Vault to open IPT/IAM in Inventor Read-Only?
Tip 14782:Command line in Autodesk Fusion.
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13599:How to read iProperties from Inventor models and drawings in AutoCAD DWGs?
Back    All CAD Tips
Categ:
