CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2911
CAD tip CAD tip # 7750:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 8640:Text formatting codes in MText objects.
Tip 3165:Autodesk applications problem with Windows 2000 Service Pack 4.
Tip 2398:How to change the Today bulletin board location for network installs?
Globally switch MText masks on/off. « | » Display line weights in Inventor drawings.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
