CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products []
Cesky English Deutsch
 Visitors: 7670
CAD tip CAD tip # 9793:
How to change the "Scale uniformly" flag for all blocks?
A - answer If you need to change the uniform scaling (X/Y/Z) flag globally, for all blocks defined in the current drawing, you can use the free UniScale utility.
Download UniScale.lsp from, load it with APPLOAD and start the command UniScaleOn or UniScaleOff.
Forced uniform scaling may cause problems e.g. when exporting P&ID drawings to AutoCAD DWG.
25.4.2014    3011×
Comments   Tell a friend
applies to: AutoCAD · PID · AutoCAD Plant 3D ·
Tip 11757:How to change blocks properties ex-post: annotative, allow exploding, scale uniformly
Tip 9302:How to change elevation units in a map or GIS source?
Tip 6785:Move attributes in multiple blocks.
Tip 6210:Various types of anonymous blocks in AutoCAD.
Tip 6179:How to make an existing block uniform-scaled or explodable?
How to change the default display style for Ortho views in Plant 3D? « | » How to visualize Inventor parts or large assemblies via internet?
