Cesky English Deutsch
Login/Register:
 Visitors: 1684
CAD tip CAD tip # 11769:
How to convert border lines (rails) to a surface?
A - answer You got a pair of border curves (polyline, spline) defining a shape in 2D or 3D space - e.g. rails, sheetmetal band, paper strip, ribbon - and you want to convert them to a surface in 2D or 3D.
To convert a pair of border lines (approximately parallel) to a surface, you can use two methods:
1. The command RULESURF (ruled surface) - select the first and the second border line, AutoCAD creates a Mesh-type object. Round segments are approximated only.
2. The command SURFPATCH - first you will need to close both curves by drawing and JOINing the end segments. The resulting closed curve can be then used in SurfPatch in the Curve option (not Edge). AutoCAD creates a Surface object, including round segments.
See also Tip 9097
ACAD
23.1.2018    1098×
Comments   Tell a friend
applies to: AutoCAD ·
Tip 11054:Difference volume (3D solid) between two TIN surfaces (sets of coordinates)
Tip 9786:3D osnaps to planes in point clouds.
Tip 9711:3DConstruct - converting a 3D mesh to a frame construct
Tip 9357:Intersection of a 3D curve with a 3D surface in AutoCAD.
Tip 9097:How to convert 3D polylines to 3D surfaces?
Export XYZ coordinates of DWG objects from AutoCAD LT. « | » Parametric constraints between 3D objects in AutoCAD.
