CAD tip CAD tip # 9024:
Question
To change case of all or selected texts in the current DWG drawing, you can use the Express Tool TCASE, or its command line version -TCASE.
It can convert selected text objects (line and paragraph texts, dimensions, attribute definitions, block attributes, rtext, arctext) to the selected mode (case) - UPPERCASE, lowercase, sentence mode (First upper), title mode (First In The Word Upper), or toggle upper-lower character (letter).
ACADADTCivilACADM
12.1.2013   16168×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical ·
Tip 13468:How to change the drawing background color in AutoCAD Web? (black drawing)
Tip 12777:Arithmetic and trigonometric functions available in Revit expressions.
Tip 12137:How to order Inventor appearances alphabetically?
Tip 11377:Annotating foundations - when they are created as walls.
Tip 10952:All DWG texts in UPPERCASE.
Back    All CAD Tips
Categ:
