CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1435
CAD tip CAD tip # 8421:
How to create a 3D propeller in Autodesk Inventor?
A - answer You can model a propeller blade (screw-propeller) using a projection of sketches and surfaces in Autodesk Inventor - as illustrated in the attached video.
See the construction procedure in the Video section or in the CAD Studio's channel on YouTube - see Inventor video #69
Propeller
or:
Inv2012Inv2011Inv2010
18.1.2012    4810x
Comments   Tell a friend
Tip 9228:How to create a knurled surface in Inventor?
Tip 8959:How to convert a 2D sketch to a 3D sketch in Inventor?
Tip 8183:Convert surface (mesh) model to 3D solid body.
Tip 7800:How to model a 3D hyperboloid?
Tip 7632:Modeling error: No solution for a vertex
Batch print for multiple drawings, multiple printers and copies. « | » Recolor entities to the color of their layer.
