CAD tip CAD tip # 8683:
Question
To make a new (or copy existing) given structure of folders and subfolders (subdirectories) in your Autodesk Vaultu repository - e.g. for a new job - you can use drag-n-drop of Windows Explorer folders.
The workflow in Vault 2013 is illustrated in the following video:
Vault2013Vault2012Inv
11.6.2012   13362×
this tip shared by ARKANCE experts applies to: Vault 2013 · Vault · 2012 · Inventor ·
Tip 14593:Revit is slow on a new workstation on structural and steel connections projects.
Tip 14374:The operation is canceled - when checking-in an Inventor assembly into Vault.
Tip 13992:How to change the color, font and appearance (bold, italic, etc.) of checked-out files in Vault?
Tip 12950:Custom installation of Autodesk 2022 CAD/BIM software products.
Tip 9968:Batch conversion of CAD files from/to the IPT/IAM, STEP, IGES, SAT, Catia... formats
Back    All CAD Tips
Categ:
