CAD tip CAD tip # 8662:
Question
You can set and retreive "environment" variables in AutoCAD LT with the SETENV and GETENV commands but there is no command to delete such variable completely.
If you really need to remove a custom variable previously set by SETENV (not just assign it to " "), you can do this in the Registry.
E.g. for AutoCAD LT 2013, you can find the SETENV variables in:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD LT\R18\ACADLT-B001:405\FixedProfile\General
Just remove the requested registry value with the name of your variable.
ACADACLT
3.6.2012   14951×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT ·
Tip 14727:Undocumented option to set up crosshair labels in AutoCAD.
Tip 14686:Environment variables in AutoCAD.
Tip 13933:How to set grid colors in AutoCAD Web?
Tip 13468:How to change the drawing background color in AutoCAD Web? (black drawing)
Tip 10444:How to hide system printers in AutoCAD PLOT dialog?
Back    All CAD Tips
Categ:
