CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1577
CAD tip CAD tip # 7262:
How to draw bearings in AutoCAD?
A - answer You can enter bearings data in any AutoCAD version. Specialized AutoCAD versions like AutoCAD Map and AutoCAD Civil 3D offer also other methods for bearings, coordinate entry and COGO.
You can use bearings format to enter angle data in standard AutoCAD relative coordinates data entry. So e.g. to draw a line 123' long, with the bearing S12°34'56"E, use:
@123<S12d34'56"E
You can enter this on any AutoCAD prompt expecting coordinate entry (Next point:, Pick point:, etc.).
ACADLTCivilMap
15.3.2010    16206x
Comments   Tell a friend
Tip 9006:Elevation label with automatic text of Level and Elevation relative to UCS.
Tip 6558:Entering angles always in degrees.
Tip 6296:How to get XYZ coordinates of a point on an Inventor assembly?
Tip 5924:Absolute and relative elevations in Revit projects.
Tip 5885:In the dynamic drawing mode, entered coordinates are considered "relative".
How to convert 2D polyline to 3D polyline? « | » Error: Inventor.exe is not currently registered
