Over 1.124.000 registered users (EN+CZ).
CAD tip # 8749:
Question
AutoCAD LT can switch Off the perspective 3D view in the current drawing by setting the PERSPECTIVE variable to 0. But you cannot switch this variable On in LT.
If you need to switch on the perspective view of a 3D scene in AutoCAD LT, you have to set the PERSPECTIVE variable in a full AutoCAD version and save it to the DWG. Such DWG file will be then displayed in perspective even in AutoCAD LT and you can use its VPOINT command to change the direction of the 3D perspective view.
ACLTDWG
8.8.2012
27133×
this tip shared by ARKANCE experts applies to: AutoCAD LT · DWG ·
