CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products []
Cesky English Deutsch
 Visitors: 6823
CAD tip CAD tip # 10791:
How to force Fusion 360 to use DirectX 9 or 11?
A - answer The CAD/CAM/CAE application Autodesk Fusion 360 automatically switches to the appropriate graphics acceleration mode. If your graphics card (or rather its driver) shows display problems in a particular DirectX mode, you can switch your Fusion 360 to use a forced graphics mode DirectX 9 or DirectX 11.
Choose "Preferences" in the menu under your login name (upper right) and under the General tab switch (from the value "Auto-select") to the selected mode in the field "Graphics driver".
12.3.2016    2304×
Comments   Tell a friend
applies to: Fusion360 ·
Tip 11522:How to create 3D splines in Fusion 360 - e.g. for pipe axes?
Cascading precedence of rental licenses. « | » Long text is not wrapped automatically to 2 lines in my title block.
