CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1688
CAD tip CAD tip # 8765:
How to get and install a localization for Revit 2013?
A - answer Revit localizations (German, French, Spanish, Russian, Czech, etc.) in a form of additional "Language Packs" (LP), one of the new features in version 2013, work differently than with other Autodesk products (see the Tip 8580).
You cannot install this LP and an add-on installation, you can only include it in the product installation. Another option is to download and install the full localized version of Revit 2013 (or the respective Building Design Suite 2013).
Steps to install LP:
  1. download the requested language pack from your Subscription center, from the Download section. Language packs are available for Revit Architecture, Revit MEP, Revit Structure and Revit 2013 ("all-in-one")
  2. Unpack the saved file
  3. Run the Revit installation and in the list box Product Language choose Add Language Pack...
  4. Select the appropriate *.msi file (they differ between 32-bit and 64-bit systems)
  5. Complete the installation
Revit2013BDS
16.8.2012    2626x
Comments   Tell a friend
applies to: Revit 2013 · BDS ·
Tip 8925:Do you know the AutoCAD command AI_DOWNLOAD_LANGUAGE_PACKS?
Tip 8691:Downloading new Autodesk software from Subscription Center.
Tip 8614:Switching Inventor UI language with Language Packs.
Tip 8580:Localization of Autodesk 2013 products using "Language Packs".
Tip 7837:Where to find the Product Key for your CAD software?
How to change all partslist cells to non-static? « | » Do I need to install SP1 before installing SP2?
