CAD Forum
Cesky English Deutsch
Login:
 Visitors: 1310
WWW server of the XANADU company (formerly: CAD Studio) Become a fan of CADforum on Facebook
CAD tip CAD tip # 6850:
How to import a new .RPC file into Revit?
A - answer In Revit 2009, 2010 and higher you can just copy your new RPC element in the .rpc format to the folder "RPCs" (typically: C:\Program Files\Autodesk Revit Architecture 2010\Data\Rendering\assetlibrary_base.fbm\RPCs).
Now load an entourage element to the current project, create a new type of this element and in its properties assign it a new rendering style - in the rendering style library you should see your newly copied RPC file.
Revit2010Revit2009
17.8.2009    1362x
Comments   Tell a friend
Share tip: Digg it! Del.icio.us Facebook Technorati StumbleUpon
applies to: Revit 2010 · Revit 2009 ·
Tip 7018:Trees are not rendered in my Revit project.
Tip 6965:How to set path for the ArchVision Content Manager (ACM)?
Tip 6630:Where are the landscape objects for AutoCAD 3D render?
Line-wrapping of text in Revit tables. « | » Change your rectangle to a true rectangle.
Have we helped you? If you want to support the CAD Forum web service, consider buying one of our CAD applications, or our custom software development offerings. You may also add a link to your web - like this "fan" link: CAD Forum - tips, utilities, blocks for Autodesk products
Export 3D VRML scenes from AutoCAD and Inventor 2010
VRMLout More info
XANADU (CAD Studio) is not responsible for possible problems that may occur as a result of using any of these tips.
