Cesky English Deutsch
Login/Register:
 Visitors: 6202
CAD tip CAD tip # 10903:
How to import an Illustrator file (.AI) into AutoCAD (.DWG)?
A - answer Most vector files from Adobe Illustrator can be directly read into AutoCAD with the function for attaching or importing PDFs. Newer versions of the .AI format have internally the PDF format (must be saved with the Illustrator option "Create PDF Compatibile File").
So you can just rename them from the extension .AI to .PDF and then use the command PDFATTACH or PDFIMPORT in AutoCAD. The file name should not contain spaces. So you can import logos, sprites or other graphical motives and pictures created in Illustrator or other vector editor.
See also: PDF/AI -> DWG
Another option is saving (exporting) the DWG or DXF file directly from Illustrator. In the export options, try the options "Preserve Appearance" or the opposite "Maximum Editatibility" for optimization of transferring text and complex splines (curve segmentation).
ACADLTInventorRevitmax
14.5.2016    7989×
Comments   Tell a friend
applies to: AutoCAD · AutoCAD LT · Inventor · Revit · 3ds Max ·
Tip 11337:Convert 3D PDF files back to CAD models.
Tip 9972:Create free 3D PDF output files from any CAD software.
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Tip 9030:Precise loading of PDF files into Autodesk Design Review (and PDF-to-DWF)
Tip 8788:Batch unification of page setups in DWG files.
Is there a command similar to Revit's "Create Similar" in AutoCAD? « | » How to get user's full domain name, phone No., department, e-mail...
