CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2064
CAD tip CAD tip # 7465:
How to import XYZ coordinates as DWG points with elevation labels?
A - answer If you need to import a number of XYZ points from Excel or a CSV file to your AutoCAD drawing, you can use e.g. using the Xls2Curve utility. Select the block option for import.
If the imported block has a proper automatic (dynamic) attribute, it will display "its own" elevation (Z-coordinate) as a text label.
See:
Tip 6692 (Xls2Curve)
Z-point block sample
ACAD
22.7.2010    5861x
Comments   Tell a friend
applies to: AutoCAD ·
Tip 7258:Export of point- and curve coordinates to Excel.
Tip 6692:Simply create points or polyline from coordinates in Excel.
Tip 194:How to import a text file with XYZ coordinates to AutoCAD points?
How to change floor level in AutoCAD Architecture? « | » One or more objects in this drawing cannot be saved to the specified format.
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
