Over 1.124.000 registered users (EN+CZ).
CAD tip # 8451:
Question
Locked layers are displayed as dimmed by default. If you don't want to change their color, you can change the setting of the LAYLOCKFADECTL variable to 0 (or to a negative value, e.g. -50). Just type it in the command line.
ACADACLT
7.2.2012
11175×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT ·
