CAD tip CAD tip # 7267:
Question
If you have a series of sequential 2D profile outlines (cross sections of a tunnel, profiles of a windsurfing board, etc.), you can create a 3D solid or 3D surface from them using the lofting process.
Start the LOFT command and pick the sequence of profiles. You can also select a path for lofting, smooth the resulting body, set draft angles, etc.
Another option is using the SWEEP command.
ACADADT
15.3.2010   15640×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture ·
Tip 13433:How to create a parametric dynamic 3D block in AutoCAD?
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 12059:Setting the G0, G1, G2 continuity of lofting.
Tip 7800:How to model a 3D hyperboloid?
Tip 2231:How to read a coordinate list into Inventor (sketch)?
Back    All CAD Tips
Categ:
