CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2917
CAD tip CAD tip # 7800:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 8322:How to extract intersection lines or edges from 3D objects?
Tip 8183:Convert surface (mesh) model to 3D solid body.
Tip 7093:How to convert a polygon or a region to 3Dfaces.
Tip 6758:Polyface mesh cannot be used for FLATSHOT command.
Tip 5878:How to convert a 3D solid to a 3D mesh?
Selectable text in PDF files from AutoCAD. « | » How to display linetypes for 3D polylines.
