Cesky English Deutsch
Login/Register:
 Visitors: 6193
CAD tip CAD tip # 9350:
How to move the draw order of all images or hatches to back?
A - answer The command DRAWORDER requests to select individual objects. But if you need to move to back (under all other drawing entities) all images or hatches, you can simplify this process with a menu macro.
In the full version of AutoCAD you can add (using CUI) the following command - LISP expression - to your ribbon or to a keyboard shortcut. It selects all drawing objects of the type Image and changes their draw order to back:
(if (setq _obr (ssget "_X" ‘((0 . "IMAGE"))))(command "_DRAWORDER" _obr "" "_BACK"))
Similarly you can move the objects "HATCH" instead of "IMAGE" - but there is already an existing internal command for this - HATCHTOBACK. The above listed macro is something like an "IMAGETOBACK".
In AutoCAD LT, where there is no AutoLISP, you can use a menu macro with similar functionality:
^C^CSELECTSIMILARMODE;0;_SELECTSIMILAR;\;_DRAWORDER;_back;SELECTSIMILARMODE;130;
It prompts to select an object (select e.g. an image) and then it moves all objects of the same type (e.g. all images) to back.
NOTE: more detailed options for controlling draworder by object type offers the CADstudio DOBT utility.
ACADLT
22.7.2013    5849×
Comments   Tell a friend
applies to: AutoCAD · AutoCAD LT ·
Tip 11570:How to create an Inventor drawing from a photo?
Tip 9255:Align image, change width/height independently.
Tip 8754:Thumbnail settings can influence AutoCAD DWG file size.
Tip 7869:New raster formats supported in AutoCAD 2012.
Tip 7654:Three methods for transparent images in AutoCAD.
Interactive display and polygon statistics of FBX, DXF, 3DS scenes « | » How to add custom paper format to AutoCAD? (grayed)
