CAD tip # 8000:
| Maximum number of tips per one unauthorized session has been reached. You can gain an unlimited access on CAD Studio's -server. |
| See also: | |
| Tip 8430: | How to add/override {} in dimension text or style? |
| Tip 7042: | List of inspection dimensions in the Inventor drawing. |
| Tip 6239: | Overriding dimension text in Revit. |
| Tip 3832: | How to quickly find dimensions with 'hardcoded' dim.text? |
| Tip 3638: | Multi-line dimension texts using control codes. |
Revit - divide parts into layers. « | » How to change a straight polyline segment to arc segment?
Featuring: Save your floating licenses (NLS) consumed by inactive users - free unused licenses with LogOff 2006
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]](../common/3d_cs2_t.gif)
CADforum Home
CAD Discussion
Tips & Tricks
Downloads
CAD Blocks
CAD Videos
Web Links
SW Development
Search
-server
