CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 2808
CAD tip CAD tip # 7844:
Maximum number of tips per one unauthorized session has been reached.
You can gain an unlimited access on CAD Studio's VIP-server.
Tip 8281:String concatenation in AutoCAD fields and block attributes.
Tip 7249:How to select all drawing entities containing a given text?
Tip 7003:Modified drawing name as an automatic field.
Tip 6559:Arithmetic expressions in AutoCAD dimensions.
Tip 6403:Select all specific texts in a drawing.
FIND does not stay zoomed on the found text. « | » Ribbon and its appearance on dual-screen configurations.
LogOff 2006 More info
