CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1901
iPROJECT - CAD document management for Intranet
CAD tip CAD tip # 7468:
How to set a variable in AutoCAD runstring (desktop icon)?
A - answer Prepare a script file (the .SCR extension) where you set the requested system variable. This file is a plain text file with a single line - e.g. to "myscript.scr" insert:
HPNAME myhatch
Save this script to the AutoCAD program or support folder.
Then add the string /b myscript.scr to the AutoCAD runstring (the desktop icon, right-click to Properties > Shortcut > Target) -- this will run your script file automatically when you start AutoCAD - e.g.:
"C:\Program Files\Autodesk\AutoCAD LT 2011\acadlt.exe" /b myscript.scr
ACADLT
23.7.2010    2351x
Comments   Tell a friend
applies to: AutoCAD · AutoCAD LT ·
Tip 8408:How to avoid save prompt after zooming or other operations?
Tip 8371:Classic hatch dialog in AutoCAD 2011,2012...
Tip 8330:Rendering stereoscopic images in 3ds Max (anaglyphs).
Tip 8318:How to convert a 3DSolid to 3DMesh or 3DFaces?
Tip 8289:Autodesk Navisworks keyboard shortcuts.
Materials missing after import of FBX file into 3ds Max. « | » How to change floor level in AutoCAD Architecture?
