Over 1.124.000 registered users (EN+CZ).
CAD tip # 9059:
Question
You can use the subscription module SDNF (Revit Extensions 2013-Q3) to convert 3D construction from AutoCAD Plant 3D 2013 to the BIM application Revit Structure 2013.
The procedure of data conversion is described in the CAD Video section - see:
or on CAD Studio's YouTube channel:
Plant2013Revit2013
29.1.2013
14594×
this tip shared by ARKANCE experts applies to: AutoCAD Plant 3D 2013 · Revit 2013 ·
