CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products []
Cesky English Deutsch
 Visitors: 2481
CAD tip CAD tip # 9889:
How to turn off Design Check Symbols in Superelevation View?
A - answer The superelevation view in AutoCAD Civil 3D may display warning symbols of design check (check standards). How to disable these symbols?
You won't find this setting in Civil styles. The warning symbol is controlled by the "Solution Tip" setting in the Options dialog box on the "AEC Editor" tab. To hide the warning symbol for all drawings, clear the Drafting check box. This option clears all alignment and profile warning symbols from the drawing window.
26.6.2014    4126×
Comments   Tell a friend
applies to: AutoCAD Civil 3D ·
Tip 11511:Assigning elevations to 2D contours (isolines).
Tip 10682:Automatic classification of drawing objects by their properties.
Tip 9916:Rotated UCS when stretching objects with grip-editing.
Tip 9625:How to color 3D topo surface model by slope?
Tip 9302:How to change elevation units in a map or GIS source?
Missing or distorted parts of the ribbon or QAT panel. « | » Inventor crashes when opening larger 3D models.
Link your AutoCAD texts with Excel tables/sheets. Export. Change. Import.
Try DwgText 2015 More info
