CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
Cesky English Deutsch
Login/Register:
 Visitors: 1753
CAD tip CAD tip # 8573:
Import Inventor 3D models into Revit.
A - answer There are several ways to transfer 3D models of parts and assemblies from Inventor to Revit. Besides the DWG format (exporting 3D model from Inventor, opening it in Revit), the ideal format for this conversion is the file exchange format ADSK (Autodesk Exchange, available since version 2010).
You can export .adsk files from Inventor with AEC Exchange (IPT,IAM). The resulting .adsk files can be imported in Revit using R > File > Open > Building Component and saves as RVT files.
InventorRevit
9.4.2012    4513x
Comments   Tell a friend
applies to: Inventor · Revit ·
Tip 6633:What is the .ADSK file format used in Inventor or Revit?
Tip 4614:How to publish DWF from SolidWorks, Pro/ENGINEER, SolidEdge or CATIA?
Tip 4497:How to set RAL or Pantone color hue in Inventor?
Tip 2356:How to add company logo to Inventor Title block?
How many CPU cores can be used for Autodesk Infrastructure Map Server? « | » Point cloud file formats in AutoCAD 2013.
